1. AC Question's Avatar
    I want to block just a number from my Alcatel pop 2
    02-27-2015 03:56 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I'm not sure if there's a Block Call function on the phone--you might want to check with your carrier to see if they can block a selected number. Otherwise, a workaround is to make that number a contact, then select it in the Contacts app, tap Menu, and check the "All Calls to Voicemail" box.
    02-27-2015 06:29 PM
  1. Replies: 9
    Last Post: 03-11-2015, 10:48 AM
  2. How is t-mobile network the fastest ?
    By Closingracer in forum T-Mobile
    Last Post: 03-08-2015, 07:37 PM
  3. Are GT-9060I and GT-9060L ROMs compatible?
    Last Post: 03-05-2015, 12:15 PM
  4. Please help in Flashing my note 3 n900t to 5.0 lollipop official firmware
    By jayson_charles in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 02-28-2015, 09:36 AM
  5. How do I open a file with an alternate application?
    Last Post: 02-27-2015, 03:51 PM
