1. AC Question's Avatar
    Recently i upgraded my Samsung Note 2 with Android 4.4.4, the phone was working well, but only one problem has surfaced. After a call, when i look for look for the red button on scree for cutting the call, the display doesn't lit up. No matter how much i press the power button/Home button or volume button, nothing happens. When anybody calls me in the meantime, he can hear my caller tune, but i cant see the call coming. Last remedy is to manually remove battery & then restart the phone. Can anybody help me identifying.... is this a software bug or hardware glitch...??
    02-28-2015 08:25 AM
  2. belodion's Avatar
    It's presumably a fault with the proximity sensor, but whether software or hardware I don't know. If it started immediately after the update, it looks like it might be software. Try a Cache Partition wipe in Recovery.
    02-28-2015 09:03 AM
  3. ullas786's Avatar
    Thanx Belidion, I tried the Cache Partition wipe in Recovery as suggested by you, but still no relief.
    Now the phone goes in hang mode, even when its kept idle. When i check the phone by pressing the pwer button, it dosent light up.
    Please help.
    03-04-2015 12:38 AM
  1. Replies: 5
    Last Post: 08-06-2015, 09:32 AM
  2. Turbo Contacts Not Responding
    By MPD648G in forum Ask a Question
    Last Post: 03-01-2015, 11:00 AM
  3. Where do my (NON-saved-contact) texts go after I've read them?
    By Anita Jay Vaughn in forum LG Optimus Series
    Last Post: 03-01-2015, 02:47 AM
  4. Why don't I have sound on my Galaxy S4?
    Last Post: 02-28-2015, 09:36 AM
  5. Why do I not have sounds for incoming texts?
    Last Post: 02-28-2015, 09:34 AM
