1. AC Question's Avatar
    On my mobile always the mobile phone number is flagges as "standard number" after transferring a new entry to the phone. I can correct it entry by entry manually (afterwards) on the phone. Is there a way to flag the correct number in Kies already before copying the number to the phone?
    03-01-2015 12:42 PM
  2. srkmagnus's Avatar
    When you enter the number in Kies it should allow you to assign the number as being default. If it doesn't, then it's best to enter the number directly into the device or on your Google account and sync it with Kies afterwards.
    03-02-2015 12:16 PM
  1. Is Chromecast not working?
    By Dylan Jenkins in forum Google Chromecast
    Last Post: 02-26-2016, 08:13 AM
  2. Note 5 based off the s6 phone specs?
    By Closingracer in forum Rumored Devices Lounge
    Last Post: 04-05-2015, 05:59 AM
  3. S6 has shown its face, I'll be sticking with the S5 :)
    By systemofadown1 in forum Samsung Galaxy S5
    Last Post: 03-31-2015, 03:55 PM
  4. Why does my led indicator not work?
    Last Post: 03-01-2015, 10:06 PM
  5. New Nexus 6 --- Unable to find/use app widgets
    By gfbiii in forum Google Nexus 6
    Last Post: 03-01-2015, 07:08 PM
