1. AC Question's Avatar
    Hi all,
    Recently this problem started surfacing for me. My phone will mysteriously mute itself, and the volume itself refuses to go up, except for ringtone. Restarting the phone fixes the problem, but then it presents itself again after a few hours.
    Thanks,
    03-01-2015 06:48 PM
  2. srkmagnus's Avatar
    Hi all,
    Thanks,
    Have you installed anything recently that may conflict with the volume settings? I'd suggest clearing cache through recovery and see if that helps.
    03-01-2015 08:39 PM
  3. AORam's Avatar
    I cleaned the cache and did a factory reset, beside losing all my personal info and apps, the volume still mutes by itself and does not want to go up. Any other suggestion?
    03-05-2015 02:51 PM
  1. Replies: 1
    Last Post: 03-01-2015, 07:01 PM
  2. Which phone is better the Samsung S6 vs Note 4?
    Last Post: 03-01-2015, 06:53 PM
  3. HTC and Valve with VR
    By Golfdriver97 in forum Virtual Reality Headsets
    Last Post: 03-01-2015, 06:20 PM
  4. Replies: 1
