1. s4u64t's Avatar
    Before a week I could charge my mobile keeping it in a certain angle. But it is of no use now ! I just wanted to that getting it repaired will destroy the other function of my mobile or not ? I heard that repairing the charging point destroys the touch of your mobile ? Help required !!
    03-04-2015 06:22 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If the technician does it correctly, it shouldn't cause any other problems. The stories you read about are likely due to poor quality repair work, or do-it-yourself repair.
    Rukbat likes this.
    03-04-2015 09:40 PM
  3. s4u64t's Avatar
    Thank you very much . I will then search for a good person for the repair work !!
    03-04-2015 10:19 PM
  4. Rukbat's Avatar
    Just make sure you have everything backed up. Some good repair people will factory reset the phone before you leave, so you know there's no personal data for them to steal when you're gone.
    03-04-2015 11:03 PM
  1. [Guide][Samsung] How to flash Stock ROM via ODIN with the New Interface
    By Rukbat in forum Ambassador Guides, Tips & How-To's
    Last Post: 03-04-2017, 08:17 AM
  2. Replies: 1
    Last Post: 03-05-2015, 05:03 PM
  3. Why can I not add any new contacts to my phone?
    Last Post: 03-04-2015, 06:22 PM
  4. Replies: 1
    Last Post: 03-04-2015, 05:50 PM
