1. AC Question's Avatar
    My dispatch sends a text but it's a email adresdress how do I get it to have its own custom notification
    03-05-2015 01:33 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which messaging app are you using, the stock Messaging one?
    I use Hangouts for SMS, and one possible way is to do the following:
    1. After you get at least one text message from the email address, go to that conversation.
    2. Tap the Menu button, then People & Options.
    3. Make sure Notifications is turned on for the conversation, and then tap Chat Message Sound to select a specific tone.
    Now, the next time you get a text from that email address (which will be added on to the conversation), it should play that specific notification tone.
    03-05-2015 06:01 PM
  3. Mike Cole4's Avatar
    I use the stock message app
    03-05-2015 11:39 PM
  4. B. Diddy's Avatar
    I'm not sure if your stock Messaging app has a similar setting. You can play around with it to see if it has anything like what I just described on Hangouts. But at least you know Hangouts is an option--and you can make Hangouts your default SMS app as well.
    03-06-2015 12:23 AM
  1. Replies: 2
    Last Post: 07-26-2015, 04:45 PM
  2. Touch Screen sensitive at top edge. Help !
    By mattlikesbikes in forum Samsung Gear S
    Last Post: 03-11-2015, 06:06 PM
  3. Can I get some help rooting my Galaxy Note Pro 12.2?
    Last Post: 03-05-2015, 12:02 PM
  4. S4 Lost Photos (SD 'Blank'). Please HELP
    By ben1989 in forum Samsung Galaxy S4
    Last Post: 03-05-2015, 12:01 PM
  5. World's first perfectly round anti-smartphone - Heirloom
    By thomas143 in forum General News & Discussion
    Last Post: 03-05-2015, 08:40 AM
