1. AC Question's Avatar
    samsung grand 2 battery got hit with something and having a small dent so is it safe to use battery performance is normal.
    03-06-2015 11:03 AM
  2. AndroidProf's Avatar
    I think its wise for you to have it checked rather than risk it leaking into the motherboard. Some batteries are usually made of a metallic casing, so dents are never deep enough to reach inside. But I think you should take it to someone for them to check.
    03-06-2015 12:23 PM
  3. Rukbat's Avatar
    There's really no way "to check" without tearing the battery apart. Considering that the battery is in the $10-$15 range, be safe and replace it. (It's not so much leakage, although that's hazardous, but if the battery shorts and goes into thermal runaway, and the phone is in your pocket, it can amputate your leg before you know what happened. Lithium batteries explode under extreme conditions. It's not worth the risk.)
    03-06-2015 05:10 PM
  1. Why is my phone on talk back mode ?
    Last Post: 03-06-2015, 06:57 PM
  2. Where is the folder for draft messages?
    Last Post: 03-06-2015, 06:54 PM
  3. Half of screen freezes on YouTube
    By robert7107 in forum Google Nexus 6
    Last Post: 03-06-2015, 04:10 PM
  4. Replies: 1
    Last Post: 03-06-2015, 10:32 AM
  5. Replies: 0
    Last Post: 03-06-2015, 10:29 AM
