1. AC Question's Avatar
    My wifi takes long to pick after changing my battery
    03-06-2015 12:43 PM
  2. Rukbat's Avatar
    One has nothing to do with the other. You're going to have to diagnose the problem closer before we can even know what the problem is, let alone help you with it.
    Are you watching the wifi screen? How long does it take for the name you want to show up? How long does it take to connect after you choose it? What kind of router are you using?
    03-06-2015 04:39 PM
  1. Verizon Lollipop: factory reset after update?
    By Jeff Harris in forum HTC One M8
    Last Post: 03-08-2015, 12:44 PM
  2. Sudden Battery Drain
    By bad43085 in forum AT&T LG G2
    Last Post: 03-06-2015, 04:44 PM
  3. Replies: 1
    Last Post: 03-06-2015, 01:55 PM
  4. Replies: 1
    Last Post: 03-06-2015, 01:25 PM
  5. How can I view a website fullscreen on a Nexus 9?
    Last Post: 03-06-2015, 12:38 PM
