1. Double Tap's Avatar
    I just downloaded Waze, when it gives directions the volume is not loud enough. Is there a way to increase the volume without having to root the phone?
    03-08-2015 10:00 AM
  2. B. Diddy's Avatar
    Media Volume is all the way up, I assume?
    03-09-2015 12:08 AM
  3. Double Tap's Avatar
    Of course
    03-09-2015 06:44 AM
  4. LeoRex's Avatar
    There may not be a way to boost the volume without root access. I've found that Waze is really quiet. Even on my Nexus 6, which has pretty loud speakers, it's hard to hear when I'm out driving. Check the sound settings in Waze... Maybe those are set low.
    B. Diddy likes this.
    03-09-2015 07:59 AM
  5. Double Tap's Avatar
    Everything set to maximum. This is very disappointing.
    03-09-2015 02:30 PM
  6. B. Diddy's Avatar
    Go to Settings>Language & Input>Text-to-Speech Output. Is it set to Google Text-to-Speech? I assume it is since it's a Nexus 4, but I figured I'd ask, in case you downloaded a separate app. This was a suggestion I saw in a Google product forum.
    03-09-2015 06:18 PM
  7. Double Tap's Avatar
    Yes, everything is set correctly.
    This is the only app with this problem.
    The volume of Google maps is OK
    03-10-2015 05:10 AM
  8. vlee's Avatar
    Just checking to see if anyone has discovered a cause/solution. Up until about a week ago, my Nexus 4 was handling Waze fine, with a reasonably adequate volume. Then suddenly, it is so low as to be almost inaudible unless I turn down my radio, which isn't loud to start with. Also noticed that when I try to increase volume with the volume button, the indicator has a Bluetooth symbol, rather than the bell symbol as the start point. I don't know if this has any relevance. I have restarted the phone, and have disabled Bluetooth in case the phone was confused where to send the sounds, but no change.
    05-24-2016 03:56 PM
  1. Major problems with my Galaxy S5
    By Corey Somers in forum Ask a Question
    Last Post: 04-09-2015, 04:04 PM
  2. Syncing HTC Desire 820 with Sony Smartband SWR10
    By Balamurugan Kannan in forum HTC Desire 820
    Last Post: 03-22-2015, 01:54 PM
  3. Can a cracked screen affect speakers and microphone?
    Last Post: 03-09-2015, 11:06 PM
  4. I'm Happy With My Dell Venue 8 7840
    By Willy_P in forum Dell Venue 8 7000 Series
    Last Post: 03-09-2015, 12:35 PM
  5. Keep going back to Nexus 5
    By scgf in forum Google Nexus 5
    Last Post: 03-08-2015, 09:51 AM
