1. Mbrzblade's Avatar
    Hi, I dropped my Samsung Galaxy Grand 2 in water but dried it and put in rice for 2 days. I turned it on and everything works perfectly. The only problem is i can see water inside it. I would be very grateful if someone could help me to fix this problem.
    03-08-2015 10:03 AM
  2. aram kadehj's Avatar
    The water droplets could have leaked between the glass and LCD ,my suggestion would be to remove the glass off the screen and see if the water drops are on the glass. If you are hesitant to do that yourself,a third party company,say at a mall or kiosk can take a look at it for you. Hope that helps
    03-08-2015 10:35 AM
  1. Unable to delete unread r starred emails?
    Last Post: 03-06-2017, 03:33 PM
  2. How to transfer Google Play movies to Gear VR?
    By TornadoQuake in forum Virtual Reality Headsets
    Last Post: 04-01-2016, 02:56 PM
  3. Why do I an SD card error message when I insert my SD Card?
    By Its_Daniel in forum Android 4.4 KitKat
    Last Post: 03-14-2015, 09:03 AM
  4. How do I make my text message look like a conversation?
    Last Post: 03-09-2015, 12:39 AM
  5. Turbo switched to Daylight Savings Time...
    By KSDroid01 in forum Motorola Droid Turbo
    Last Post: 03-08-2015, 11:13 PM
