1. AC Question's Avatar
    there are never power warnings or anything it just stops - and wont turn back on - when the charger is first plugged in it shows dead but at the first green line it will let you turn it back on then it immediately says it has 83-85% of battery and indicates 100% within a half hour - what could the problem be?
    03-08-2015 06:53 PM
  2. belodion's Avatar
    A fault in the battery, perhaps. Read these guides by Rukbat:
    [GUIDE] Is My Battery Shot?
    [Guide] The Care and Feeding of Lithium Polymer Batteries
    03-08-2015 07:19 PM
  3. Rukbat's Avatar
    Sounds like a dendrite to me - a really bad one. If you can't get the store to understand that it's a manufacturing defect, go to Amazon and look for an Anker or Hyperion battery (or 2 and a charger) for your phone. Even the expensive ones are under $15, so I wouldn't wast too much time fighting for a factory replacement, just ask and see if they'll do it. If not, oh, well. If you smoke, that's just 3 packs.
    03-08-2015 07:59 PM
  1. Why is my Galaxy S4 all of a sudden running out of space?
    By Vibrating Wafflez in forum Ask a Question
    Last Post: 03-09-2015, 10:52 PM
  2. Samsung Galaxy S4 - Calendar Issue
    By joelasylum in forum Samsung Galaxy S4
    Last Post: 03-09-2015, 12:48 PM
  3. Installation with error code of '504', please help!
    By Xia Gu Cao in forum Google Nexus 7 Tablet (2013)
    Last Post: 03-09-2015, 08:25 AM
  4. Replies: 1
    Last Post: 03-08-2015, 09:41 PM
  5. Why is my GT-s7560 shutting down with 85 of the battery?
    By AC Question in forum Samsung Galaxy Tab
    Last Post: 03-08-2015, 07:26 PM
