A
The LED might indicate the phone is charging or recognizing that it is plugged into a power source. Let it sit on the charger for a few hours then try rebooting. If that doesn't work contact Boost or the manufacturer for a fix/replacement.My boost mobile hydro edge is not turning on and the indacator light is orange why?
