A AC Question Mar 13, 2015 #1 I have it drying in one of those dry kits my question is what color should the light under the battery be ? Thanks joi
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,581 4,711 113 Visit site Mar 13, 2015 #2 Welcome to Android Central! Do you mean the water damage indicator sticker? Usually, it turns a solid color if it's been exposed to water. That color can be red or blue or some other color--it depends on the phone or the carrier. Upvote 0 Downvote
