1. AC Question's Avatar
    I have it drying in one of those dry kits my question is what color should the light under the battery be ? Thanks joi
    03-13-2015 09:21 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you mean the water damage indicator sticker? Usually, it turns a solid color if it's been exposed to water. That color can be red or blue or some other color--it depends on the phone or the carrier.
    03-13-2015 10:33 AM
  1. Replies: 1
    Last Post: 05-02-2015, 02:37 PM
  2. Why doesn't my led notification light work on my LG Tribute?
    Last Post: 03-13-2015, 10:49 AM
  3. Why am I receiving my text messages delayed??
    Last Post: 03-13-2015, 09:04 AM
  4. How can i check my recent calls?
    Last Post: 03-13-2015, 08:52 AM
