1. AC Question's Avatar
    It's all about my phone which is - note 2 . My phone has got a problem like its been stuck at the screen which shows - downloading do not switch off the target I guess . So what should I do to fix this problem .
    03-16-2015 11:57 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It sounds like you booted into Download Mode (which happens when you power on by pressing Power, Home and Vol Down). As long as you're not connected to your computer and actively flashing a ROM, you can power the phone off again, and then power on normally by just pressing the Power button. If there's no clear way to power off, just press and hold Power for about 10-15 seconds until the phone shuts off.
    Were you trying to get into Recovery Mode instead?
    03-17-2015 03:14 PM
  1. S-Note issues....
    By zr2s10 in forum Samsung Galaxy Note 10.1
    Last Post: 04-18-2015, 10:43 PM
  2. why are all my apps saying unfortunately this has stopped?
    Last Post: 04-09-2015, 10:06 PM
  3. Replies: 5
    Last Post: 04-09-2015, 01:00 PM
  4. Problems with Volume Controls
    By Dylan Gorski in forum Google Nexus 6
    Last Post: 03-16-2015, 06:55 PM
  5. Why are my Note 4 hangouts and stock sms blurry pictures?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-16-2015, 11:45 AM
