1. AC Question's Avatar
    Got notification that my Nexus 10 tablet was ready to do the OTA update to Android 5.1. I OK'd the download and gave permission to install the update. During the update, the Android Icon appeared with the red triangle ! above his torso with a simple "error" message underneath. Then the tablet spontaneously rebooted. I checked the tablet info and it said I was still at 5.02. After a couple of tries, I couldn't get the tablet to search for updates to see if I could give it another try.
    Anyone else have this problem?
    03-17-2015 07:36 AM
  2. LeoRex's Avatar
    Is your tablet rooted or modified in any way (custom recovery, etc?)
    There are a bunch of requisite checks that the OTA upgrade goes through before it loads the update. If you are getting that error, it is tripping one of those checks.
    03-17-2015 10:21 AM
  3. zworld's Avatar
    I am having the same problem with my Nexus 5. Yes, I am rooted, but I'm not using a custom ROM. Is there a fix for this other than un-rooting the device?
    03-17-2015 01:21 PM
  4. LeoRex's Avatar
    If you are stock, just unroot the device. Every method will most likely require you to re-root the device once you update.
    There are other ways to update, like manually flashing via fastboot... but even those will require you to re-root the phone.
    03-17-2015 02:41 PM
  5. zworld's Avatar
    Thanks. I was hoping to avoid resetting my device and avoid the app re-install process. Oh well. :-)
    03-17-2015 04:27 PM
  1. Replies: 7
    Last Post: 05-21-2015, 08:12 PM
  2. Replies: 1
    Last Post: 03-18-2015, 05:28 PM
  3. S6 review said to be a masterpiece
    By HOLLYWOODANT215 in forum Samsung Galaxy S6
    Last Post: 03-18-2015, 06:26 AM
  4. Asus Nexus slow after latest android update
    Last Post: 03-17-2015, 07:56 AM
  5. Sky go says device is rooted, how do I know if it is?
    Last Post: 03-17-2015, 07:35 AM
