1. AC Question's Avatar
    its coming only 97, 96 like is there any problem
    03-18-2015 06:19 AM
  2. AMedviediev's Avatar
    Is the phone or battery new? Apparently, lithium batteries have to be calibrated during the first couple of uses for optimal performance.
    Also, did you update the phone's software recently?
    03-18-2015 10:11 AM
  3. Rukbat's Avatar
    That's a myth. I have no idea where it started, but it should go back there.
    It should be conditioned for 3 cycles - totally different.
    Leave the charger plugged in at least overnight and see if it gets up to 100%. (Also, make sure you're using the stock charger. A lower voltage charger [lower by 0.1 Volt or 0.2 Volt] won't get the battery up to full charge in some phones.)
    The Care and Feeding of Lithium Polymer Batteries
    03-18-2015 06:35 PM
  1. Why won't my Android Net Book work?
    Last Post: 03-19-2015, 10:47 AM
  2. sd card not recognised
    By balbertat in forum HTC One M8
    Last Post: 03-18-2015, 06:38 PM
  3. Note3, Lollipop 5.0 & battery problem
    By Mandor Sawall in forum Samsung Galaxy Note 3
    Last Post: 03-18-2015, 11:24 AM
  4. Why won't my alarm ring in vibrate mode?
    Last Post: 03-18-2015, 05:32 AM
