1. AC Question's Avatar
    When i plug in the charger into my Samsung galaxy s2 it connects and it hows the little eletricity charge icon like if its charging, But it just stays like that it wont change, i thought the problem was the battery then i bought a new one, but the problem still here... What can i do?
    03-18-2015 04:32 PM
  2. belodion's Avatar
    Check that the charger is good, and also that the USB lead and USB port are clean and undamaged.
    03-18-2015 04:51 PM
  3. Cleidir Ivandro's Avatar
    I think charger isnt the problem, cuz i use it to charge another phones
    belodion likes this.
    03-18-2015 05:06 PM
  4. belodion's Avatar
    Welcome as a new member.
    I think that a faulty charger was the least likely explanation....but that still leaves the USB lead and the USB port, both of which are more likely to become damaged in normal use. Hopefully it will be the lead, which will be easy and cheap to replace. See whether you can try one first, that you know to be good.
    03-18-2015 06:45 PM
  1. Why is my Galaxy Note 4 laggy with games?
    Last Post: 03-31-2015, 12:24 PM
  2. Does the one M8 charge for emoticons?
    By AC Question in forum HTC One M8
    Last Post: 03-20-2015, 08:01 AM
  3. Replies: 2
    Last Post: 03-18-2015, 07:07 PM
  4. Samsung Galaxy SGH-I747 Recovery?
    Last Post: 03-18-2015, 04:13 PM
  5. Replies: 1
    Last Post: 03-18-2015, 02:20 PM
