1. AC Question's Avatar
    My battery was at 93% and I plugged it into my car charger to top it off before going into work. Less than a half a mile later, my battery was at 100%. It has never charged this fast before.
    Now that I think about it - my battery has been fluctuating; some days it drains faster than normal and other days it drains as it did before the upgrade to 5.0; I don't have any applications running in the background (I checked the applications running and battery info screen). I have the samsung galaxy s5. Thanks!
    03-19-2015 07:59 AM
  2. Almeuit's Avatar
    Sounds like the phone just wasn't reading the battery right. There isn't charging that fast .
    03-19-2015 02:56 PM
  3. Rukbat's Avatar
    7% in 5 minutes would be 80 minutes for a full charge, which is slower than 1C (the maximum recommended charge rate). 7% in 1 minute would be a 4C charge - which would damage the battery (and even in 1 minute, the battery would get pretty hot). I'd say Almeuit is right, and either the battery is flaky or you should condition it. (The Care and Feeding of Lithium Polymer Batteries)
    03-19-2015 03:25 PM
  1. How can I install the Facebook app on my mobile (again) ?
    Last Post: 03-21-2015, 10:40 PM
  2. Why is my Samsung Grand Duos i9082 battery draining so fast?
    By Slainte1965 in forum Ask a Question
    Last Post: 03-21-2015, 10:38 PM
  3. Replies: 1
    Last Post: 03-20-2015, 08:55 AM
  4. Replies: 1
    Last Post: 03-19-2015, 03:28 PM
  5. My mobile data is not getting turned on , why is that ?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 03-19-2015, 08:35 AM
