1. AC Question's Avatar
    Is it possible to control sound for apps separately? For example, I like to start Songza, then start a running app. I'd like to be able to control the volume for each app separately, so turn down Songza and turn up running louder.
    Right now adjusting the volume just makes all sounds that the apps make go louder or quieter together. Is there a way to do this separately?? Thanks!
    03-19-2015 02:00 PM
  2. qwerty6532's Avatar
    This might be possible with the Play Store app Tasker.
    Rukbat likes this.
    03-19-2015 02:47 PM
  1. Lollipop update for Note 4 in the UK?
    By Nik Brooks in forum Samsung Galaxy Note 4
    Last Post: 06-20-2015, 05:35 PM
  2. Replies: 5
    Last Post: 06-10-2015, 09:12 AM
  3. Predictions for OEM support and updates
    By 88 FLUX in forum Android Auto
    Last Post: 03-22-2015, 07:23 AM
  4. Replies: 1
    Last Post: 03-21-2015, 10:21 PM
  5. Suggestions for a sun hood?
    By uscpsycho in forum Google Nexus 7 Tablet (2013)
    Last Post: 03-20-2015, 12:55 PM
