1. AC Question's Avatar
    Since the best prices for both phones are from online sellers and not through Tmobile, I would like to know that the model I'm getting has the right bands for Tmobile. Some of the sites have conflicting information, so I'm not exactly sure what sites to trust.
    03-19-2015 10:03 PM
  2. Crashdamage's Avatar
    You need to know the sub-model number. Then go to this site to find out if it will work:
    http://www.willmyphonework.net/
    Android since v1.0. Linux user since 2001.
    03-19-2015 10:09 PM
  3. Rukbat's Avatar
    The F, the European model, is the easiest to get, it has an unlocked bootloader (unlike the A and the V) and it will work on TMobile or AT&T (or Verizon). Just make sure it's SIM-unlocked (or what's called "factory unlocked"). Of course the T will work. (And the W8 will work.)
    Crashdamage likes this.
    03-19-2015 11:54 PM
  4. culda1984's Avatar
    Thank you! That site looks promising.
    03-21-2015 07:34 PM
  5. culda1984's Avatar
    Thank you for the information. Also how reliable is the site posted by Crashdamage? According to it, almost all models work with Tmobile except for maybe 2 or 3. I'm new to the technical world, so what does unlocked bootloader mean?
    03-21-2015 07:39 PM
  6. Rukbat's Avatar
    For the 3 or 4 carriers I checked, they're accurate, even to future expansion plans. As far as I know, AT&T is using a single band all over the country, but they're listing the ones AT&T plans to expand to, so you'll know whether the phone will continue to work in the future.
    It means you can put in a custom ROM, an custom kernel, a custom recovery - you have control over your phone, the carrier doesn't. A locked bootloader is like a desktop that can only use WD hard drives and Radeon graphics cards. Or a car that can only use BP gas. You're getting half a phone. (I'm not new to the technical world, I've been in it for ... well, I took my first radio apart in about 1949 [couldn't get it back together without help, but it was a start], and I still bought an AT&T phone with a locked bootloader. AT&T wouldn't recognize it now, except for the logo on the case, but I still can't do everything I want to it.)
    03-21-2015 08:03 PM
  1. Replies: 3
    Last Post: 03-20-2015, 04:05 AM
  2. Why won't my Galaxy Note 10.1 2014 screen light up?
    By AC Question in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-20-2015, 12:40 AM
  3. Battery info Samsung S5
    By RionDunn in forum Samsung Galaxy S5
    Last Post: 03-19-2015, 10:01 PM
  4. Android 5.0 volume difference Samsung S5
    Last Post: 03-19-2015, 09:46 PM
  5. Replies: 0
    Last Post: 03-19-2015, 09:13 PM
