1. AC Question's Avatar
    It was working fine till about 1 hour back, i turned it off and now that i am trying to press the switch on top to start it wont come on. The battery was at 80 percent and it was connected to the charger .I am very sure the battery is fully charged by now. Please help. thanks
    03-21-2015 01:12 PM
  2. belodion's Avatar
    Have you tried a long press, say for a minute or two?
    Otherwise, the power switch under the button may have failed, among other possibilities.
    03-21-2015 01:17 PM
  1. Need help with gaming on the Note 4
    By asanatheist in forum Samsung Galaxy Note 4
    Last Post: 03-23-2015, 10:25 PM
  2. Replies: 2
    Last Post: 03-22-2015, 10:44 AM
  3. Can the wireless display be completely turned off?
    Last Post: 03-21-2015, 04:55 PM
  4. Android logo stuck on Edge panel after Swarm update
    By MattFisher515 in forum Samsung Galaxy Note Edge
    Last Post: 03-21-2015, 02:48 PM
  5. Replies: 1
    Last Post: 03-21-2015, 01:02 PM
