1. AC Question's Avatar
    When I connect my phone to a charger, it won't charge unless I restart the phone after I connect the charger. Once it has fully charged, the battery icon doesn't change to reflect the actual charge unless I once again restart the phone after it is disconnected. Is anyone else experiencing this?
    03-21-2015 03:39 PM
  2. Raptor007's Avatar
    Can you tell us which model phone you have, how old it is, are you using an OEM battery or 3rd party battery and are you using the OEM Charger. It could be a combination of issues related to that. Please offer more info so we can help.
    Rukbat likes this.
    03-21-2015 03:41 PM
  1. The performance is just...meh
    By frugo in forum Moto E (2015)
    Last Post: 07-18-2015, 02:51 PM
  2. Replies: 2
    Last Post: 03-21-2015, 05:01 PM
  3. Can I get some help getting the radio to work?
    By AC Question in forum Samsung Galaxy Ace
    Last Post: 03-21-2015, 04:59 PM
  4. Why won't my Galaxy S4 update to Lollipop?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 03-21-2015, 04:32 PM
  5. Why won't apps install on my LG G3?
    By cj1234505 in forum LG G3
    Last Post: 03-21-2015, 03:39 PM
