1. AC Question's Avatar
    When using both my M8s via the HDMI lead everything, picturewise, is pefect but when I use the AV connection the picture is either massive or way too small and I can't seem to adjust it to get a satisfactory picture size. I've tried adjusting both the TV and also adjusting the video size in Kodi.
    Is there a solution to this ?
    03-23-2015 02:39 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What kind of AV connection are you referring to? HDMI is always the preferred method of connection. Are you using some sort of microUSB-to-composite cable?
    03-23-2015 04:29 PM
  3. chris4u's Avatar
    It's the cable that was supplied with the box, jack plug one end which goes into the back of the M8 and 3 jacks on the other (tv) end (red, white and yellow)
    03-23-2015 07:37 PM
  4. B. Diddy's Avatar
    Does it connect to the phone's headphone jack, or the microUSB port?
    03-24-2015 12:48 AM
  5. sa congo's Avatar
    B. diddy it almost like your joking around with the post, how dont you know audio and video cable is a type of connection to view on older tv. he even explain the connection and your like some kind of microusb. How would you fix this if the screen is constantly flipping. would someone help???
    03-18-2016 05:04 PM
  1. Can I make a shortcut to a file on my SD card?
    By relztrah in forum General Help and How To
    Last Post: 03-25-2015, 12:17 PM
  2. Replies: 2
    Last Post: 03-23-2015, 04:12 PM
  3. ART Runtime on Lollipop 5.0.1 N910F
    By Mohammed Mulla1 in forum Samsung Galaxy Note 4
    Last Post: 03-23-2015, 02:57 PM
  4. I can not get my Android 4.1 JellyBean to turn on. What could be the cause?
    By AC Question in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-23-2015, 02:33 PM
  5. Replies: 0
    Last Post: 03-23-2015, 02:04 PM
