1. AC Question's Avatar
    The LED setting for notifications are preset. How can I change this setting?
    03-24-2015 08:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Light Flow is the most popular app for this.
    03-24-2015 05:12 PM
  3. Hypnotoadd's Avatar
    Depending on whether you only want to change it for some functions (for example, texts) there may be options within the app you already have that you can change. For instance, several texting apps have options for changing at least the LED color. If you want to do more, yeah you probably need lightflow.
    03-24-2015 05:37 PM
  1. Replies: 2
    Last Post: 05-05-2015, 10:08 PM
  2. Replies: 6
    Last Post: 03-31-2015, 07:08 AM
  3. Why isn't my Xolo Q1200 displaying contact names and photos?
    By Arun Sagar in forum Android 4.4 KitKat
    Last Post: 03-24-2015, 05:20 PM
  4. Replies: 1
    Last Post: 03-24-2015, 05:18 PM
  5. Why do I receive error code 67 on my HTC Evo 4G?
    By AC Question in forum HTC EVO 4G
    Last Post: 03-24-2015, 07:32 AM
