1. AC Question's Avatar
    I am looking to be able to silence the shutter sound on my G3 when taking photographs. Is this possible? I have not found anything in camera settings nor general sound settings on my phone. Thanking someone in advance!
    03-24-2015 07:04 PM
  2. Josiah23's Avatar
    First thing you can try is to go to the Camera App - Settings - Shutter Sound - Off.
    If that doesn't work, then you can try turning the volume of the phone down or put it in silent mode when taking photos.
    The last option is to Root your phone. Once Rooted, go to this folder on your phone: /system/media/audio/ui and rename the camerashutter and/or cameraclick OGG files to something else.
    http://www.phonetipsandtricks.com/ti...ter-sound-122/
    Hope this helps.
    03-24-2015 07:24 PM
  1. Why can't I factory reset or update my htc one x+?
    By Bruno Mishtaku in forum Ask a Question
    Last Post: 04-11-2015, 05:05 PM
  2. Why does my battery drain so fast sometimes?
    Last Post: 03-25-2015, 09:35 AM
  3. Why is my camera on my phone all black
    Last Post: 03-24-2015, 07:36 PM
  4. Can I get some help connecting my S5 to my PS3 via dnla?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-24-2015, 06:25 PM
