1. AC Question's Avatar
    Hi all
    Went to flash stock 5.1 today cos I was sick of waiting. All was fine, backed up using NRT, installed 5.1. Then tried to restore my backup using NRT, and now whenever I turn on the phone it is at the "Welcome: Setup" screen with select a language. The problem is, two errors keep popping up. "Unfortunately, Nfc Service has stopped" and "Unfortunately, Phone has stopped".
    I have gone into recovery mode and done both a factory reset and just a cache wipe but neither are solving it.
    I would appreciate some help so much if anyone can
    Thanks so much in advance.
    03-25-2015 05:24 AM
  2. DLK1's Avatar
    Maybe you got a bad download. Can you download the Flash ROM again and try to flash it again?
    03-30-2015 11:49 AM
  3. LeoRex's Avatar
    What version is NRT attempting to load? Find where Wugfresh is installed on your computer and go to "WugFresh Development\Nexus Root Toolkit\data\Factory_Images"
    There you should find a directory like "hammerhead-LMY47I-factory-df12798".... what do you see there?
    And are you doing a full wipe (you can choose to not wipe your userdata with the NRT)?
    03-30-2015 12:01 PM
  1. Why does my phone hang a lot?
    Last Post: 03-25-2015, 07:43 AM
  2. Replies: 1
    Last Post: 03-25-2015, 07:37 AM
  3. How can I get access back to my custom ringtones?
    Last Post: 03-25-2015, 05:54 AM
  4. Replies: 0
    Last Post: 03-25-2015, 04:16 AM
  5. Replies: 0
    Last Post: 03-25-2015, 03:37 AM
