1. AC Question's Avatar
    irulu 9 inch when plugged in it flashes a screen with battery with lighting bolt but that is green. When unplugged it won't turn on. Any ideas on how to fix or what is wrong? I don't think it is charging either.
    03-25-2015 12:53 PM
  2. belodion's Avatar
    The fault may be with the charger, USB lead, USB port, battery, or elsewhere. Check the USB lead first....see whether moving it while attempting to charge makes a difference. If so, the lead may need replacing, or the USB port may be dirty or damaged.
    03-25-2015 01:08 PM
  1. Why does the wifi not turn on, Galaxy S4?
    Last Post: 04-02-2015, 02:29 PM
  2. Replies: 1
    Last Post: 03-26-2015, 12:44 AM
  3. How to fix update g900vvru1b0a8 on my samsung galaxy S5?
    Last Post: 03-25-2015, 05:22 PM
  4. Replies: 1
    Last Post: 03-25-2015, 12:25 PM
  5. About to leave Sprint for T-Mobile, need to install generic ROM on Galaxy S4
    By tonylmiller in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-25-2015, 11:01 AM
