1. AC Question's Avatar
    My phone is alternating between charging and not charging when plugged in. A couple times it's been charging then just stopped and wouldn't start again. At the moment it will just stop charging for a bit and then start back up. The back and forth seems to be with the wall charger. The car charger seems to be more of the stop and not start back up variety. The phone is a Samsung Galaxy Nexus that's a couple years old.
    03-26-2015 03:20 PM
  2. xceeder's Avatar
    Try using a different cable and plug and see if it works if not then the pins in your phone may be a bit bent so have a look at the pins if the new charger doesn't make any difference..
    Sent from my Nexus 7
    belodion likes this.
    03-26-2015 03:32 PM
  1. Problem with battery life and screen coming on
    By pjo1966 in forum LG G Watch
    Last Post: 05-07-2015, 04:22 AM
  2. Moto X2 Running Hot w/ Rapid Battery Drain
    By KawaiiKristi in forum Ask a Question
    Last Post: 03-26-2015, 12:06 PM
  3. Fast charging on/off
    By kirksucks in forum Samsung Galaxy Note 4
    Last Post: 03-26-2015, 11:11 AM
  4. Can you explain my poor battery life?
    By bbmjack in forum Samsung Galaxy Note 4
    Last Post: 03-26-2015, 10:33 AM
  5. Replies: 1
    Last Post: 03-26-2015, 07:18 AM
