1. AC Question's Avatar
    All, new to the forum and could really use some help. I know there are a ton of threads out there about WiFi connectivity issues with the Galaxy S3, and I've read through dozens of them, tried the solutions, but still have the same problem.
    Basically my WiFi disconnects as soon as the phone goes to sleep (about 5 minutes after I haven't touched the phone). It will reconnect automatically when woken up. I have done everything that i've seen advised on many threads, but still seeing the issue. Here is what i can tell you about my device:
    1. Smart Network Switch deactivated
    2. Keep WiFi on during sleep set to 'Always'
    3. Forgot network, reconfigured network.
    4. Power save mode turned off (Device, not Wifi)
    Some things that aren't working
    1. Tried dialing #0011# but it won't work. Get error message that states 'Connection error or invalid MMI code'. I have power save mode set off, but it sounds like there is a power save mode specifically for wifi when dialing this code.
    i had performed a factory reset a few weeks ago and just got my device configured back to the way i want, would really like to avoid doing that again.
    Does anybody know of any other solutions or point me to a thread where the above has failed for other users? Thank you!!
    03-27-2015 02:40 PM
  2. itguyjax8430's Avatar
    Have you tired this 6 Ways How To Fix Connection Problem or Invalid MMI Code to fix the error code? Fixing it could lead you to fix the WiFI problem.
    03-27-2015 02:56 PM
  3. Rukbat's Avatar
    *#0011# - you forgot the *
    But even with wifi power saving on (menu/Wifi, when you get to the *#0011# screen - last line) wifi should still work when the phone is sleeping.
    Exactly what is the symptom you're trying to cure?
    03-27-2015 04:20 PM
  1. How to shut off screenshot sound? HTC One M8
    Last Post: 11-06-2016, 03:59 AM
  2. Why can the receiver of a Magic Jack call not hear my voice?
    Last Post: 03-28-2015, 02:37 AM
  3. Replies: 1
    Last Post: 03-28-2015, 02:36 AM
  4. Replies: 0
    Last Post: 03-27-2015, 02:36 PM
  5. Replies: 1
    Last Post: 03-27-2015, 02:22 PM
