1. AC Question's Avatar
    When I go to open a app or emails or google does not matter what it is I get a white screen an then wait an wait till it might open, I installed ES Files Explore to delete files I no longer needed an also I uninstalled apps Im not using thinking maybe I have to much going on an yea still white screen with like this thing in the middle going in circles even when I want to make a call white screen thing going in circles an I have also noticed lately that over night my phone does not charge to 100% like it use to I might get 60%-75%. Its just very frustrating, any suggestions on what I can do I really appreciate it
    Thank You for your help, DeDe
    03-28-2015 12:53 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    03-28-2015 01:28 AM
  1. Is GPRS still supported for data by AT&T and T-Mobile?
    Last Post: 03-30-2015, 08:52 AM
  2. Replies: 1
    Last Post: 03-30-2015, 08:49 AM
  3. Replies: 1
    Last Post: 03-28-2015, 03:32 PM
  4. How do I get my info off a broken Samsung S4 phone?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 03-28-2015, 01:44 AM
  5. Replies: 1
    Last Post: 03-28-2015, 01:31 AM
