Why can't I mount /system rw?
A
AC Question
Hello,
I have Huawei Honor 3C and I just cannot get to make /system writable.
Does anybody know how to solve this?
I will provide every info you will need if you write me.
Thanks, Dominik.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Do you have a superuser app installed? Are you using a file manager app to mount /system, or are you mounting it in adb? (If the latter, you have to run su before trying to remount /system.)
Emekekwue otito
I also have the same problem plsss help me I have rooted hav used all the apps play store provides four mounting r/w still doesn't solve am trying to use freedom but it keeps telling me only works with read system partition
