1. AC Question's Avatar
    Searched all the internetz high and low for this problem without finding anything...
    So while playing music (Spotify for instance) I can turn screen off and keep audio playback as usual. But as soon as I press the power button to turn screen on and show the lock screen my audio gets cut off. The track keeps playing, it actually goes on pause for a split second in the lockscreen widget but immediately continues playback, just no audio coming thru on headphones, the speaker or bluetooth/AUX -connection.
    Haven't been able to find a single post mentioning a similar problem. Phone is Nexus 5 with Lollipop 5.0.1
    Thanks,
    assco
    03-30-2015 12:31 PM
  2. srkmagnus's Avatar
    Check the app settings to see if there is anything to disable turning off when lock screen is enabled. There should be an option in the settings.
    03-30-2015 01:37 PM
  1. Why are SMS notifications when messaging is open ?
    Last Post: 04-14-2015, 08:00 AM
  2. Music Controls on Lock Screen
    By iamadoorknob in forum Android 5.0 Lollipop
    Last Post: 03-31-2015, 11:28 PM
  3. Replies: 7
    Last Post: 03-31-2015, 02:46 PM
  4. Touch Screen is not working - Help Troubleshooting the Problem
    By ejcrossl in forum Samsung Galaxy Note 4
    Last Post: 03-30-2015, 06:15 PM
  5. just updated to Lollipop, but I don't really see anything different?
    By TENYKS in forum Samsung Galaxy Tab S 10.5
    Last Post: 03-30-2015, 06:07 PM
