How do I uninstall the BATTERY DOCTOR?
A
AC Question
How to uninstall the BATTERY DOCTOR
how to uninstall the battery doctor? every sin i have installed the battery doctor my phone drains in 5 min.Please help me !!!!
LeoRex
Retired Moderator
Nov 21, 2012
6,223
Re: How to uninstall the BATTERY DOCTOR
Long press the app's icon in your app drawer, then drag it to 'Uninstall'
You can also go into Settings-Apps... from there if you select the app, you should also be able to access the screen where you can uninstall.
calvinxander08
