1. AC Question's Avatar
    I turn off all the options, I tried deleting power consuming apps, and under battery, screen takes up 35% of the battery. I dont know if this is normal. What do I do?
    04-01-2015 07:31 AM
  2. belodion's Avatar
    Welcome to the forums.
    It would be more helpful if you check your battery stats at the end of the day, before you recharge, and see what are the main users of charge. Screen will almost always top the list.... that's normal. It's the next few under that that may be more revealing. Also, your signal strength is relevant. A bad signal will use more battery.
    If you want to register as a member and post screenshots of stats, this guide from B. Diddy will be useful if you're not sure how to proceed:
    http://forums.androidcentral.com/amb...d-central.html
    Don't forget to let us know your screen-on time as well.
    04-01-2015 07:41 AM
  3. MichaelIkel1's Avatar
    screen on has been 31minutes. the phone has been on for an hour now
    04-01-2015 08:19 AM
  4. belodion's Avatar
    Welcome as a new member.
    Post the stats later and we'll have a go at diagnosing.
    04-01-2015 08:49 AM
  5. MichaelIkel1's Avatar
    When should I post the stats? after it reaches zero? Or whenever?
    04-01-2015 11:08 AM
  6. belodion's Avatar
    The best way of getting an idea of what may be causing trouble is to charge to 100%, use the phone as normal until it falls to the sort of level at which you would normally recharge, then take screenshots of the stats before recharging.
    'The level at which you would normally recharge' will obviously vary from one user to another. The best practice for a long-lived healthy battery is to recharge at 40-50% but it's not always possible or practical to do that. Let it drain as much as you normally do, then screenshot and post the stats.
    04-01-2015 12:12 PM
  7. MichaelIkel1's Avatar
    04-02-2015 08:57 AM
  8. MichaelIkel1's Avatar
    the screen usage is known to spike to 40% however, but this is after usual usage. Then I charged it right afterwards.
    04-02-2015 08:58 AM
  1. How can I get my Galaxy S5 to turn on?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-06-2015, 12:06 PM
  2. How I can disable update notification of Lollipop in Moto G2?
    Last Post: 04-01-2015, 10:40 AM
  3. Why is my phone saying Lg keyboard has stopped?
    Last Post: 04-01-2015, 07:49 AM
  4. How can I fix my frozen phone?
    By AC Question in forum LG G2
    Last Post: 04-01-2015, 06:44 AM
  5. Rooting..how do I know what ROM I need?
    By allysisa in forum General Help and How To
    Last Post: 04-01-2015, 05:12 AM
