1. AC Question's Avatar
    Hi all,
    I have a Samsung Galaxy S4, and recently have noticed that the Location Services functionality (which I normally leave turned off as it burns battery) would turn on/activate on its own. It took me a while but I finally watched it happen. It occurs when the 15% low battery warning message displays (or perhaps is cleared).
    I was wondering if anyone else noticed this happening, and if there was a way to prevent the location service from automatically turning on when the battery is low.
    Thanks!
    04-01-2015 10:35 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! When Location Services turns on, what is it set to? High Accuracy? Battery Saving? I wonder if the low battery alert triggers some Power Saving mode, which makes sure that Location is set to Battery Saving--but if designed poorly, will actually turn on Location in order to make sure it's set to Battery Saving, instead of leaving it off as you had selected.
    For what it's worth, if Location Services is set to Battery Saving, it should use very minimal battery. If it's set to High Accuracy (i.e., using GPS), that can eat up more battery. Also, make sure Location Reporting is turned off.
    04-01-2015 10:41 AM
  3. Leslie Underhill's Avatar
    Mine does that too. I'm going to check into what the other comment suggested!
    06-03-2015 01:11 AM
  4. luckypox's Avatar
    I only see one reply on this. I have an S5 with Lolipop and have exact same problem, can anyone advise if this is in fact due to having no Battery saving mode on? I didn't have this issue with kit kat. Frustrating.
    06-04-2015 09:28 PM
  5. Loumz13's Avatar
    No it shouldn't. Check your settings in Lookout if you have it installed and untick "signal flare"
    Krissb likes this.
    06-24-2015 06:32 PM
  6. Alex Wallin's Avatar
    I'm pretty sure it has something to do with a security app saving your location. Like for if you were a lost child or you lost your phone, in order for you or someone else, to be able to track it.
    Avast maybe, just check out those kind of apps.
    Hope that helps!
    07-02-2015 10:14 AM
  7. Kelly Kearns's Avatar
    I use Wheres My Droid and it has the signal flare feature and I think Lookout has it also, from when I used to use that. I have mine set to go off at 5% battery though.
    07-02-2015 12:10 PM
  8. Moii_ep3's Avatar
    Yup, it was my Lookout app. "Signal Flare" was enabled.
    07-03-2015 04:01 PM
  9. Kelly Kearns's Avatar
    It isn't a bad idea to have the signal flare on, because if something happens to your phone and the battery dies, you know where it was at 1% or 15%, whatever number you set it to.
    07-06-2015 10:30 AM
  10. Automne's Avatar
    I have been looking for this answer for so long. Thank you, my phone is healed.
    03-10-2016 11:00 PM
  11. Krissb's Avatar
    I went into lookout, and sure enough signal flare was on! It says it will save your last location before the phone dies, hence why GPS kept turning on when it would reach 15%
    05-29-2016 09:08 AM
  1. Battery doesn't last at all now
    By bjballar41 in forum LG G3
    Last Post: 04-01-2015, 05:49 PM
  2. Which smartwatch should I get?
    By AC Question in forum Droid RAZR M
    Last Post: 04-01-2015, 11:36 AM
  3. Replies: 1
    Last Post: 04-01-2015, 10:49 AM
  4. Replies: 1
  5. Is there an Ringer Volume on & off Timer app?
    Last Post: 04-01-2015, 10:42 AM
