1. cglennon01's Avatar
    Out of the blue my messages come to me in random order and behind messages I've sent. Driving me nuts! I've restarted and also powered off but nothing helps.
    04-03-2015 05:19 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Are you using the stock messaging app? Have you tried using another messaging app like Google Messenger or Chomp SMS to see if it does the same thing with those apps?
    You can also try resetting the messaging app by going to settings, application manager, all app, scroll to the messaging application and hit clear data. You may lose all your text messages but might be worth a shot to fix the issue.
    04-04-2015 09:10 AM
  1. Stock Messaging App
    By jtb79 in forum HTC One M9
    Last Post: 04-07-2015, 12:14 PM
  2. Replies: 1
    Last Post: 04-04-2015, 09:01 AM
  3. How do I get my adobe flash player..it says it's out of date
    Last Post: 04-04-2015, 02:40 AM
  4. how do i prevent someone from harrassing me?
    Last Post: 04-03-2015, 10:49 PM
  5. Proper Flashing order
    By bkircher in forum Google Nexus 6
    Last Post: 04-03-2015, 05:26 PM
