1. AC Question's Avatar
    I can't for the life of me figure out how to turn on the god forsaken battery saver on my Verizon note 4! I don't have the menu button once i go into the battery options. It's like it doesn't exsist...
    04-06-2015 10:24 PM
  2. belodion's Avatar
    Welcome to Android Central.
    I'm not familiar with that device, and excuse me if this is obvious, but you've opened the 3-dot menu at top right in Settings, Battery?
    04-07-2015 04:16 AM
  3. ronandrew's Avatar
    You can open setting on device and check battery option
    04-07-2015 05:11 AM
  4. mookie840's Avatar
    Yes that's the 3 dots I'm referring to. They aren't there, the only thing that's there is a refresh button, which makes no sense.
    04-07-2015 10:51 AM
  5. anon8380037's Avatar
    Have you got a Power Saving quick toggle switch on the shade. Try holding that for more options.
    (Idk though, Note 3 here.)
    Ask in the Note 4 forum also.
    04-07-2015 11:25 AM
  1. Replies: 3
    Last Post: 08-18-2015, 01:14 AM
  2. How to return to Stock. Verizon Note 3 running AllianceROM
    By MatixMovies in forum Verizon Samsung Galaxy Note 3
    Last Post: 04-21-2015, 07:54 PM
  3. Anything you're NOT happy with on the Note Edge?
    By droidntn in forum Samsung Galaxy Note Edge
    Last Post: 04-13-2015, 11:11 AM
  4. Replies: 1
    Last Post: 04-08-2015, 09:30 AM
  5. Fixing Blacklisted and unlocking the Note 4
    Last Post: 04-06-2015, 08:30 PM
