1. AC Question's Avatar
    I'm working the night shift tonight, have the galaxy S5 with 27% battery and wanna set the alarm later to have a nap but I'm afraid I'll run out of battery, alarm doesn't ring and I don't wake up.
    Does it work in "ultra power saving mode"?
    04-10-2015 04:11 PM
  2. UJ95x's Avatar
    Welcome to the forums!
    When you set up UPS, you can select which apps will continue to work. If you select your alarm app, it should still ring
    04-10-2015 04:14 PM
  1. Replies: 1
    Last Post: 08-06-2015, 08:58 AM
  2. 115 gb of OneDrive -- how do you get it?
    By sankavarmuch in forum Samsung Galaxy S6
    Last Post: 06-05-2015, 11:06 PM
  3. Replies: 1
    Last Post: 04-10-2015, 04:27 PM
