1. AC Question's Avatar
    I want to try using a (cut) modified mini usb/usb cable to directly charge the battery of my old flip phone (Verizon VX 5200). (I don't have the big fat chip size charger.) But when I strip the (mini/usb) end of the cord to expose the wires, there are 4 colored wires, red, white, yellow and green, but NO BLACK!What's the deal with this? Is the cable I intended to use only a data cable and not a charging cable, or does another color act as the black negative wire in this instance> Thanks in advance. And, yes, I will be careful if I can first figure out the answer to this question. :-)Thanks in advance. Looking forward to a quick answer as well!
    04-11-2015 06:58 PM
  1. Replies: 7
    Last Post: 04-21-2015, 02:28 PM
  2. How do I get to the clipboard on a HP desk top?
    Last Post: 04-12-2015, 02:21 AM
  3. i was wondering how to turn down touch sensativity on note 4
    Last Post: 04-11-2015, 06:46 PM
  4. Replies: 0
    Last Post: 04-11-2015, 06:44 PM
