1. Sanam Marvi's Avatar
    my s4 is too warm during use is there any solution?
    04-12-2015 10:20 AM
  2. Josiah23's Avatar
    How many apps are currently running? By killing those apps that are running and your not using them, that could lower the temp of your S4.
    Sent from my SM-G900V using Tapatalk
    04-12-2015 10:21 AM
  3. Sanam Marvi's Avatar
    how to check that how many apps are running
    04-12-2015 12:46 PM
  4. Josiah23's Avatar
    Well I'm currently using a s5 so it will be different, but try looking I'm settings then go on application manager.
    04-12-2015 01:29 PM
  5. Sanam Marvi's Avatar
    ok thanks
    04-12-2015 01:46 PM
  1. Lollipop Update Install on Galaxy S4 "Software Update Interrupted" Fix
    By jdbowman2000 in forum AT&T Samsung Galaxy S4
    Last Post: 10-18-2015, 12:25 PM
  2. Problem seeing screen in daylight on s6
    By justkenny in forum Samsung Galaxy S6
    Last Post: 06-30-2015, 08:48 AM
  3. Galaxy S4: can't change keyboard color
    By nw7789 in forum Ask a Question
    Last Post: 04-12-2015, 12:11 PM
  4. Cyanogenmod for SCH-I545 S4 and SM-G900V S5
    By Josiah23 in forum Samsung Galaxy S4
    Last Post: 04-12-2015, 10:51 AM
  5. Samsung Galaxy S5 Problems
    Last Post: 04-12-2015, 10:38 AM
