1. AC Question's Avatar
    All Android developer people please elaborate any problem with software data cable and relevant solution to it!
    04-13-2015 03:24 AM
  2. Rukbat's Avatar
    What problem? Using the original cable or an aftermarket cable? Or one that came with another device? (Non-data devices, like wireless headsets, often come with charging-only cables. Saving 2 wires in the cable, over millions of cables, is a lot of money.) Are you sure it's the cable and not the USB port? (Don't use an external USB hub - plug into the computer directly.)
    "Any problem" doesn't give us much to work on.
    04-13-2015 10:58 AM
  1. diamond coolpad problems sdcard?
    Last Post: 04-13-2015, 12:13 PM
  2. What is the APN number for the Galaxy S5?
    By Charlie Gittings in forum Samsung Galaxy S5
    Last Post: 04-13-2015, 10:59 AM
  3. Have a Note 4 and lost all of my calendar data
    Last Post: 04-13-2015, 08:54 AM
  4. Replies: 0
    Last Post: 04-13-2015, 02:28 AM
  5. What is the current version of Android for Samsung Tab Style 10.5 ?
    By AC Question in forum Samsung Galaxy Tab 10-inch
    Last Post: 04-13-2015, 01:55 AM
