1. AC Question's Avatar
    Seems like since the update to Lollipop, the battery drains within hours and lately the phone has been pretty warm.
    04-13-2015 09:06 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    Corrupt files on the SD card are a common cause of overheating and battery drain. Try unmounting the card (in Settings>Storage) and removing it, then reboot. Insert the card into your computer and run chkdsk to look for bad sectors: [GUIDE] Using chkdsk to fix a corrupted SD card
    04-13-2015 11:45 AM
  3. intulsa's Avatar
    yes, since the update all the battery goes to android os and system. screen is only at 5%. Fine before the update.
    04-14-2015 07:12 PM
  1. Verizon Wireless online complaints
    By mdk32014 in forum Verizon
    Last Post: 06-08-2015, 10:15 AM
  2. Battery question
    By bvitale in forum Verizon Galaxy Note 2
    Last Post: 04-13-2015, 12:36 PM
  3. How do I close hundreds of apps opened on my Samsung Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-13-2015, 10:48 AM
  4. Replies: 1
    Last Post: 04-13-2015, 08:53 AM
  5. Replies: 1
    Last Post: 04-13-2015, 08:47 AM
