1. AC Question's Avatar
    I upgraded from a Note 4 to an S6 Edge over the weekend. On the Note 4 the pedometer appears on the lock screen and there is an option in Settings to hide it. On the S6 it does not appear on the lock screen and when I go to Settings->Lock Screen and Security -> Show information there is no option for the pedometer, just the dual clock and weather. The S Health app does count steps but I have to open the app to see them, and there are no options within the app to display the steps on the lock screen.
    Is there any way to display the pedometer on the lock screen?
    This is using Android 5.0.2 and S Health 4.0.0.0150
    04-13-2015 01:09 PM
  2. NathanHL's Avatar
    Same problem with Note 5 and Android 5.1.1
    I seem to remember that I had the step count when I first got the phone but I disabled it and now the option to put it back is gone
    11-21-2015 06:25 AM
  3. Vestina's Avatar
    I'm facing same issue with S6 Edge, have you found any solution?
    01-05-2016 03:45 AM
  1. LG G3 and Android Auto (definitely not working)
    By Phil Nickinson in forum Android Auto
    Last Post: 01-29-2017, 10:48 AM
  2. Battery usage data not available
    By Zendroid1 in forum Samsung Galaxy S6
    Last Post: 04-14-2015, 03:16 PM
  3. Replies: 1
    Last Post: 04-13-2015, 04:10 PM
  4. My Whatsapp says I have 1 message but I can't find it
    Last Post: 04-13-2015, 02:54 PM
  5. Replies: 2
    Last Post: 04-13-2015, 01:30 PM
