1. AC Question's Avatar
    why is my batery draining so fast?, got fully charge buy it drained really fast!
    max SD micro card 32,64 or 128 for a Samsung gakaxyS5 S900
    04-13-2015 11:15 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! A corrupt file on an SD card is a common cause of battery drain. Unmount the card (in Settings>Storage), remove it, and insert it into your computer. Run chkdsk to look for bad sectors: [GUIDE] Using chkdsk to fix a corrupted SD card
    Also, seeing some battery stats would help. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    04-14-2015 12:19 AM
  1. My Galaxy S6 Edge (Tmobile) has blueish tint band on screen
    Last Post: 04-14-2015, 12:35 AM
  2. Replies: 1
    Last Post: 04-14-2015, 12:22 AM
  3. My HTC1 notification bar went Facebook blue a few days ago
    Last Post: 04-14-2015, 12:21 AM
  4. Screen is black & won't do anything
    Last Post: 04-13-2015, 11:33 PM
  5. What is the maximum micro sd card for a Galaxy 5 S900?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-13-2015, 11:08 PM
