1. AC Question's Avatar
    I recently bought a RCA Pro 10 Edition RTC6203W46 tablet, and am looking for a spare charger for it so that I do not need to unplug and bring into another room or location.
    Tried Amazon but shows one or two available, but coming from China and would take a month + to get here?!
    Any help on where I can find/purchase one would be greatly appreciated!
    Thank you!
    04-14-2015 06:20 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you looking for an extra charger for the tablet, or is the battery removable and you're looking for a charger for the battery?
    If you're looking for an extra charger, is the tablet's charge port a microUSB port, or a proprietary DC socket?
    04-14-2015 06:54 PM
  3. Rukbat's Avatar
    If it's a microUSB port, try a dollar store. Chargers are pretty much interchangeable these days. the cheap ones can put out up to 1 Amp, the more expensive ones can put out up to 2 Amps. the only difference is that if your tablet can draw more than 1 Amp, charging with a 1 Amp charger will be slower.
    04-18-2015 01:19 AM
  1. Can't install Facebook app
    By Tanay Saluja in forum Ask a Question
    Last Post: 04-13-2017, 05:27 PM
  2. when is the lollipop download coming for the droid maxx?
    Last Post: 05-27-2015, 09:48 PM
  3. How can I optimise the performance of my S5?
    Last Post: 04-14-2015, 07:29 AM
