1. Shakil Shaideen's Avatar
    i i bought a phone from etisalt called besocial 4 and when i came home i tried connecting to my wifi etisalt it doesnt connect it says connecting then it says saved secured wep even when i try it with my friends house it says the same. when i try it with another wifi thats not etisalt it works pls help. i tried everything
    04-14-2015 12:40 PM
  2. srkmagnus's Avatar
    Have you reset the router to see if that fixes the problem? If not, consider a reset of the WiFi router and see if that works. You might have to try a factory reset as well if there still isn't an improvement with connecting to the WiFi router. Otherwise, you might want to contact the carrier for a possible replacement if it turns out to be a hardware problem.
    04-14-2015 04:36 PM
  1. Crackling Audio Problem
    By Kayla Beers in forum Samsung Galaxy S6
    Last Post: 01-28-2017, 04:49 PM
  2. How do I Login to Wifi where a password is required?
    Last Post: 04-14-2015, 05:51 PM
  3. Can I get some help with my HTC ONE M8 Wifi Problem?
    By AC Question in forum HTC One M8
    Last Post: 04-14-2015, 05:41 PM
  4. How can I connect wifi etisalt?
    Last Post: 04-14-2015, 05:39 PM
  5. Can I get some help with Google Messenger group text problems?
    Last Post: 04-14-2015, 11:33 AM
