1. AC Question's Avatar
    I'll be traveling in Europe and don't want to be bothered by incoming calls that would be outrageously expensive. Is there a way that I can block them on my S5?
    04-19-2015 09:26 AM
  2. Rukbat's Avatar
    Airplane mode. (In most cases you won't be getting any, because you won't be connecting to your carrier's towers.)
    studiumcirclus likes this.
    04-19-2015 11:15 AM
  3. studiumcirclus's Avatar
    You can also try apps like RCB (remote call block) but most require root. Leaving your phone in airplane mode as has already been suggested would be the best option
    04-19-2015 01:29 PM
  4. Javier P's Avatar
    As Rukbat said, aeroplane mode is the best way and you can switch WiFi on & off when you need it. Also, in most countries buying a prepaid SIM card is very cheap and you can use it for local calls or mobile data. For example, right now I'm in Spain using one. Free sim card and 5 euros for 500Mb. More than enough to use with online messages and calls.
    04-20-2015 01:40 AM
  1. My S6 is doing stuff on its own? How do if ix it?
    By greatprince99 in forum Samsung Galaxy S6
    Last Post: 04-19-2015, 07:30 PM
  2. Replies: 1
    Last Post: 04-19-2015, 03:39 PM
  3. Replies: 1
    Last Post: 04-19-2015, 03:29 PM
  4. Replies: 1
    Last Post: 04-19-2015, 03:24 PM
  5. How can I find out the manufacture date of a Galaxy Note 4?
    By felloffthetruck in forum Samsung Galaxy Note 4
    Last Post: 04-19-2015, 01:28 PM
