How to keep Unlimited Data Plan on Verizon
A
AC Question
I upgraded through Verizon and had the phone shipped to my house. I have not turned it on yet, hoping to try the best buy trick. My old phone the galaxy s3 has micro sim and the galaxy s6 takes a nano sim. What do I need to do to keep unlimited data on Verizon? Thanks all tips appreciated.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Search on Android Central for threads on that - there have been a few. I think what you need is a second line, and you upgrade on that line, then use the new phone on the UDP line. (If that's what you're doing, about the only thing you can do is use a SIM cutter - very carefully.)
