1. AC Question's Avatar
    I want to use tasker to turn on hotspot on my Note 4 Edge ATT when I enter my car, The trigger is my bluetooth connection. I can create the trigger, but can't figure out how to turn the hotspot feature on as it is 3 or 4 levels down in the settings menu.
    04-22-2015 08:38 PM
  2. Rukbat's Avatar
    Set a task for turning it on. It's in Net/Wifi Tether. Set it to on for that task. Trigger the task with the Bluetooth connection. (I'd also set an exit task to turn it off so you don't have to remember to turn it off when you leave the car.)
    04-22-2015 11:09 PM
  1. Replies: 4
    Last Post: 04-23-2015, 07:22 AM
  2. How can I get my cell to stream music in my car via bluetooth?
    Last Post: 04-23-2015, 01:09 AM
  3. Why am I unable to connect to wifi?
    Last Post: 04-23-2015, 01:06 AM
  4. Traitor to S6 -Thinking about Note 4
    By Brian Delaney in forum Samsung Galaxy Note 4
    Last Post: 04-23-2015, 12:59 AM
